Daihatsu Charade 3cyl 993cc non-turbo
Links to Diesel Engine Manuals available online
Post by mark_in_manchester »
I have a paper copy of the above manual, which came from New Zealand (!), and which I've never found anywhere else. Non-turbo, which is a pain as mine is a turbo...
But pretty much useless except for part numbers and torque settings - mostly a set of exploded diagrams with a few of these things added on. If you're really stuck, message me.
Re: Daihatsu Charade 3cyl 993cc non-turbo
if that is an unbound paper copy or one you can seperate the pages.... then yourself or a friend with an ink jet "office" style printer/fax youl find it likely has ability to "scan to PDF". You can then make it much more accessible via the net.
Thanks for offering.
Rhynri
Post by Rhynri »
Also, if anyone is ever needing something digitized, i'll be happy to do it for you.
