Punsun Dnepr build with questions
sno-bro
Re: Punsun Dnepr build with questions
Post by sno-bro »
Sibbo wrote:Sno Bro, have you calculated your road speed at 3000 rpm?
A great looking build mate ! :D
Hi Sibbo. Yes I have.
Assuming a 215cm length of the rear wheel, my very fast 4th gear (1:1) and standard rear drive (8:37) will make
3000rpm 83kmh
3600rpm 100kmh
If they start to seem too slow I can easily update the rear drive to 9:35 which will increase the speeds to
3000rpm 99kmh
3600rpm 119kmh
There is still an option of 10:32 rear drive but I doubt I'll go that route: First of all the first gear will be really tall which makes driving in traffic difficult, and there are no gears available to correct the speedometer error.
Also it is good to remember that the bike handling is based on very very old technology designed for slow speeds. The suspension and brakes are not up to the task.
sno-bro
Sibbo
Post by Sibbo »
3000rpm 83kmh
3600rpm 100kmh
3000rpm 99kmh
3600rpm 119kmh
sno-bro
She's going to be a brilliant bike Sno-Bro :D , especially with a 9.35 rear end , 90 km is a nice cruising speed and it's probably at the top of the torque curve too.
Speedo ? do what Norton riders do , use a bicycle computer. Dead accurate and cheap.
A good way around the brakes would be a laced in Honda front drum brake or similar .It shouldn't be that noticeable and they are truly good!
Congratulations mate, she is great! :D
res0wc18
Post by res0wc18 »
Did you ever finish this bike?
sno-bro
Post by sno-bro »
Hi,
yes I did. You can see some pictures in the following discussion:
https://www.dieselbikeforum.com/view ... =31&t=2301
the discussion includes a link to a short video.
The bike still runs fine! Although it does leak some oil and fuel that I need to attend to.
sno-bro
