I've got a lombardini engine which I've taken the cylinder heads off and there is heavy carbon buildup in the exhaust ports. Is this quite common with generator engines as they sit as the same rpm for long periods?
I don't want to go at it with some sharp implement and damage the aluminum underneath, and wire brushes aren't going to be able to reach half of the areas. Any tips on how to go about this or is it a job best left to an engineering shop/vapour blasters?
Cleaning exhaust ports
Re: Cleaning exhaust ports
<--2Da^ (back to the top) for this poor fella that never got a responce
Sorry, only saw the thread now... BIO-DIESEL will help to loosen the carbon enough, so you can clean it off with a bit of wood.Benzine wrote:I've got a lombardini engine which I've taken the cylinder heads off and there is heavy carbon buildup in the exhaust ports. Is this quite common with generator engines as they sit as the same rpm for long periods?
Carbon build-up exceeding a certain level is not normal and you should start looking for the cause. Valvestem-seals are likely for example or simply worn rings.
Cheers,
Greg
