Aerodynamic & rolling resistance, power & MPG calculator
For Spreadsheets, Gear Ratios, Speed Calculation etc..
Sibbo
Post by Sibbo » Sun Jul 31, 2011 10:31 am
http://ecomodder.com/forum/tool-aero-ro ... stance.php
This calculator is good .
If you feed in 1.0 as the coefficient of drag for a normal unfaired bike......................... cd ,
rolling resistance for normal tires on a paved road 0.015 crr ...................... Is that right ? or higher?
I used .75 squ m as frontal area
Engine efficiency 40% ...........correct for a China diesel ?
Tick diesel as fuel .
It gives a pretty accurate estimate of speed and fuel efficiency .
I calculated the coefficient of drag of the Dreamliner fairing I posted once before and it's cd came up as .72 .
No wonder it improved fuel efficiency so much .
It calculated fuel consumption on the Dreamliner as 1.4 l/100km, Imp mpg 200 or US mpg 168 at 76km phr or 47 mph .
Sibbo
Re: Aerodynamic & rolling resistance, power & MPG calculator
Post by Sibbo » Mon Aug 08, 2011 11:45 pm
I've modified the engine efficiency to 30% on advice from the forum ...thanks !
The most interesting modification is changing the coefficient of drag figure .The boys on this site http://ecomodder.com/forum/motorcycles-scooters.html come up with some remarkable stuff .If you plug .7 into cd and rework the calculation the results are very good .
220 kg weight
cD .6
frontal area 7 squ ft
biodiesel
results in 1.25 l/100km or 226 mpg Imp at 45 mpg using 3.18 hp .
the same with a cD of 1
gives 1.94 l/100km or 145 mpg Imp at 45 mpg . Quite a difference ! 8)
