Offset Enfield sprocket?
Clutches, Chain & Belt Drives
Anorak_ian
Post by Anorak_ian » Thu Feb 24, 2011 7:41 pm
I'm looking for an offset sprocket for the 5 speed Enfield box, anyone know if they are available?
Will Harley sprockets fit the Enfield 5 speed?
Ian
Answer: No, and no they don't. :(
oldbmw
Re: Offset Enfield sprocket?
Post by oldbmw » Fri Mar 25, 2011 8:29 pm
shouldn't be too difficult to fabricate using one old sprocket for the boss and a new one for the drive. If you did it would mean you could run o ring chain in an Electra. ATM there is not enough clearance on the primary drive side. Naturally you will need to shim the wheel to align the sprockets.
Anorak_ian
Post by Anorak_ian » Fri Mar 25, 2011 10:01 pm
It's a toss up at the moment whether I fit the 5 speed or fix up and use the old 4 speed.
If I go ahead and use the 5 speed I have a 23 tooth Harley dished sprocket (£10) to weld up to the 17 tooth Enfield. Talon wanted £53 for a special made up sprocket for the 5 speed (not offset).
It's all fun and games again, racing it back to the road in a bit of a panic. :D
Post by Sphere » Sun Mar 27, 2011 2:06 pm
Are you on a clock to get it rolling again? :roll:
Anorak_ian
Post by Anorak_ian » Sun Mar 27, 2011 4:10 pm
I'm getting withdrawal symptoms, the good weather is here and my bikes in bits again (hopefully for the last time).
Cornwall is just 2 miles down the road, with its pretty villages and long winding open country roads, it's just what the diesel is crying out for. :D
Post by Sphere » Sun Mar 27, 2011 5:48 pm
Mmmm, I do suspect you will also want to check out the local brew while on a run 8)
Anorak_ian
Post by Anorak_ian » Tue Mar 29, 2011 8:36 am
Oh, there's an idea :D
